Hallo in die Runde,
ich bekomme nach Update von 4.3.12(?) auf 4.3.15 nachfolgende Fehlermeldungen, obwohl das Update an sich ohne Fehler durchgelaufen ist. Vllt eine kleine Zusatzinfo, da ich die Meldung habe, dass meine php Version keine Updates mehr erhielt habe ich auch auf von php 8.0 auf php 8.4 durchgeführt.
Kann vllt. jemand helfen? Vielen Dank!
Deprecated: Session::setCookie(): Implicitly marking parameter $secure as
nullable is deprecated, the explicit nullable type must be used instead in
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/system/classes/Session.php
on line 461 Deprecated: Session::start(): Implicitly marking parameter
$secure as nullable is deprecated, the explicit nullable type must be used
instead in
on line 518 Warning: Undefined global variable $_SESSION in
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/system/common.php
on line 61 Fatal error: Uncaught TypeError: array_key_exists(): Argument #2
($array) must be of type array, null given in
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/system/common.php:61
Stack trace: #0
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/overview.php(18):
require_once() #1 {main} thrown in
on line 61
Deprecated: User::__construct(): Implicitly marking parameter $userFields
as nullable is deprecated, the explicit nullable type must be used instead
in
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/system/classes/User.php
on line 90 Deprecated: User::changeRoleMembership(): Implicitly marking
parameter $leader as nullable is deprecated, the explicit nullable type
on line 182 Deprecated: User::checkRolesRight(): Implicitly marking
parameter $right as nullable is deprecated, the explicit nullable type must
be used instead in
on line 371 Deprecated: User::editRoleMembership(): Implicitly marking
on line 849 Deprecated: User::setRoleMembership(): Implicitly marking
on line 2052 Warning: session_start(): Session cache limiter cannot be sent
after headers have already been sent (output started at
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/system/classes/User.php:90)
in
on line 573 Deprecated: Language::__construct(): Implicitly marking
parameter $languageDataObject as nullable is deprecated, the explicit
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/system/classes/Language.php
on line 62 Deprecated: ChangeNotification::prepareUserChanges(): Implicitly
marking parameter $user as nullable is deprecated, the explicit nullable
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/system/classes/ChangeNotification.php
on line 94 Deprecated: ChangeNotification::logUserChange(): Implicitly
on line 161 Deprecated: ChangeNotification::logRoleChange(): Implicitly
on line 216 Deprecated: ChangeNotification::logUserCreation(): Implicitly
on line 260 Deprecated: ChangeNotification::logUserDeletion(): Implicitly
on line 312 Deprecated: Smarty::_getTemplateId(): Implicitly marking
parameter $template as nullable is deprecated, the explicit nullable type
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/libs/server/smarty/smarty/libs/Smarty.class.php
on line 1048 Deprecated: Smarty_Internal_Data::getTemplateVars():
Implicitly marking parameter $_ptr as nullable is deprecated, the explicit
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_internal_data.php
on line 193 Deprecated: Smarty_Internal_Data::_mergeVars(): Implicitly
marking parameter $data as nullable is deprecated, the explicit nullable
on line 203 Deprecated: Smarty_Internal_Template::__construct(): Implicitly
marking parameter $_parent as nullable is deprecated, the explicit nullable
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_internal_template.php
on line 149 Deprecated: Smarty_Resource::source(): Implicitly marking
parameter $_template as nullable is deprecated, the explicit nullable type
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_resource.php
on line 175 Deprecated: Smarty_Resource::source(): Implicitly marking
parameter $smarty as nullable is deprecated, the explicit nullable type
on line 175 Deprecated: Smarty_Resource::populate(): Implicitly marking
on line 199 Deprecated: Smarty_Template_Source::load(): Implicitly marking
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_template_source.php
on line 158 Deprecated: Smarty_Template_Source::load(): Implicitly marking
on line 158 Deprecated: Smarty_Internal_Resource_File::populate():
Implicitly marking parameter $_template as nullable is deprecated, the
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/libs/server/smarty/smarty/libs/sysplugins/smarty_internal_resource_file.php
on line 28 Deprecated: Smarty_Internal_Resource_File::buildFilepath():
on line 101 Deprecated: HtmlNavbar::__construct(): Implicitly marking
parameter $htmlPage as nullable is deprecated, the explicit nullable type
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/system/classes/HtmlNavbar.php
on line 79 Deprecated: HtmlForm::__construct(): Implicitly marking
parameter $action as nullable is deprecated, the explicit nullable type
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/system/classes/HtmlForm.php
on line 110 Deprecated: HtmlForm::__construct(): Implicitly marking
on line 110 Deprecated: HtmlForm::openGroupBox(): Implicitly marking
parameter $headline as nullable is deprecated, the explicit nullable type
on line 1787 Deprecated: HtmlTable::__construct(): Implicitly marking
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/system/classes/HtmlTable.php
on line 87 Deprecated: HtmlTable::addRowTypeByArray(): Implicitly marking
parameter $arrAttributes as nullable is deprecated, the explicit nullable
on line 131 Deprecated: HtmlTable::addRowFooterByArray(): Implicitly
marking parameter $arrAttributes as nullable is deprecated, the explicit
on line 157 Deprecated: HtmlTable::addRowHeadingByArray(): Implicitly
on line 172 Deprecated: HtmlTable::addRowByArray(): Implicitly marking
on line 190 Deprecated: HtmlTableBasic::addColumn(): Implicitly marking
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/system/classes/HtmlTableBasic.php
on line 182 Deprecated: HtmlTableBasic::addRow(): Implicitly marking
on line 229 Warning: Cannot modify header information - headers already
sent by (output started at
in
/customers/8/0/1/vfb-handball.net/httpd.www/admidio/adm_program/system/classes/HtmlPage.php
on line 432
Fehler nach Update auf 4.3.15
schoenburg06
- MightyMCoder
- Developer
Re: Fehler nach Update auf 4.3.15
Hallo schoenburg06,
Das Problem scheint dadurch zu entstehen, dass deine Installation deprecated Warnungen sendet, bevor eine Session angelegt werden kann.
Schau mal nach, ob in deiner php.ini der Wert „display_errors“ auf „On“ steht. Falls ja, setze diesen Wert auf „Off“. Damit sollte es wieder funktionieren.
Wenn du auf Nummer sicher gehen möchtest oder weiterhin Fehler angezeigt bekommen möchtest, kannst du noch „error_reporting“ auf den Wert „E_ALL & ~E_DEPRECATED & ~E_NOTICE“ setzen. Das verhindert, dass Deprecated und Notice Meldungen reported werden.
Bei mir läuft Admidio in der Version 4.3.16 mit PHP8.4.12 mit „display_errors=Off“ ohne Probleme.
MightyMCoder
MightyMCoder
schoenburg06
Habe den Punkt in den globalen Einstellungen des Webspaces gefunden und abgeschalten, vielen dank!
