Easier Role & Permission Management?
trevoratkins
Beitrag von trevoratkins »
Hi everyone, I’m using Admidio and really like it so far, but managing roles and permissions can get a bit complicated with larger groups. Is there a simpler way to handle multiple roles or view permissions more clearly? I’d love to hear how others are dealing with this or if there are any useful tips.
buildingexuberant
Re: Easier Role & Permission Management?
Beitrag von buildingexuberant »
this is likely expected behavior. Users can sometimes see basic contact entries but get a “no permission” message when opening profiles.
To fully hide contacts, remove access to the Contacts module or adjust role permissions (especially default roles like “Registered users” or event-related roles).
If it still happens, check which roles the user has—there’s probably a permission coming from there.
RVice
Beitrag von RVice »
You can use the "Category report" and put all the rows as columns. In the csv export the column the member is assigned to will have an 'X' in it.
That's at least how I've done it and then export it to Excel/Google Sheets to manipulate it into something I can print for the folks that like to have things in hand.
