1.4a: Fehler beim Anlegen von Terminen
toschi269
Beitrag von toschi269 »
Beim Anlegen von Terminen bekomme ich die folgende Fehlermeldung. Die Termine werden trotzdem in der Datenbank angelegt und sind auch abrufbar
Warning: main(iCalendar_rfc2445.php): failed to open stream: No such file or directory in /var/www/web1/html/domains/thahn/igsfv/adm_program/libs/bennu/bennu.inc.php on line 5
Warning: main(): Failed opening 'iCalendar_rfc2445.php' for inclusion (include_path='.:/usr/lib/php') in /var/www/web1/html/domains/thahn/igsfv/adm_program/libs/bennu/bennu.inc.php on line 5
Warning: main(iCalendar_components.php): failed to open stream: No such file or directory in /var/www/web1/html/domains/thahn/igsfv/adm_program/libs/bennu/bennu.inc.php on line 6
Warning: main(): Failed opening 'iCalendar_components.php' for inclusion (include_path='.:/usr/lib/php') in /var/www/web1/html/domains/thahn/igsfv/adm_program/libs/bennu/bennu.inc.php on line 6
Warning: main(iCalendar_properties.php): failed to open stream: No such file or directory in /var/www/web1/html/domains/thahn/igsfv/adm_program/libs/bennu/bennu.inc.php on line 7
Warning: main(): Failed opening 'iCalendar_properties.php' for inclusion (include_path='.:/usr/lib/php') in /var/www/web1/html/domains/thahn/igsfv/adm_program/libs/bennu/bennu.inc.php on line 7
Warning: main(iCalendar_parameters.php): failed to open stream: No such file or directory in /var/www/web1/html/domains/thahn/igsfv/adm_program/libs/bennu/bennu.inc.php on line 8
Warning: main(): Failed opening 'iCalendar_parameters.php' for inclusion (include_path='.:/usr/lib/php') in /var/www/web1/html/domains/thahn/igsfv/adm_program/libs/bennu/bennu.inc.php on line 8
Warning: Cannot modify header information - headers already sent by (output started at /var/www/web1/html/domains/thahn/igsfv/adm_program/libs/bennu/bennu.inc.php:5) in /var/www/web1/html/domains/thahn/igsfv/adm_program/modules/dates/dates_function.php on line 182
Schau mal ob es bei dir den Ordner adm_program/libs/bennu gibt und ob dieser auch 6 Dateien enthält ?
Hast du beim Update vorher den kompletten Ordner adm_program gelöscht und dann neu kopiert ?
toschi269
fasse hat geschrieben:Schau mal ob es bei dir den Ordner adm_program/libs/bennu gibt und ob dieser auch 6 Dateien enthält ?
Hallo fasse,
ich habe eine Neuinstallation von 1.4a durchgeführt. Ja, es sind alle sechs Dateien im bennu-Ordner. Wie geschrieben, die Fehlermeldung kommt zwar, abrufbar sind die Termine aber trotzdem. Übrigens: Der Export von ical geht gar nicht.
Ich hab dir mal eine korrigierte Datei zugeschickt. Schau mal, ob es damit klappt.
toschi269
fasse hat geschrieben:Ich hab dir mal eine korrigierte Datei zugeschickt. Schau mal, ob es damit klappt.
Hallo fasse,
danke für die beiden Dateien. Leider keine Änderung.
weblinks sind gar nicht anzulegen. Bei den Terminen gibt es zwar eine Fehlermeldung, die Termine werden aber richtig angezeigt und können auch (mit weiterer Fehlermeldung) gelöscht werden.
Auch hier die Frage, kommen exact dieselben Fehlermeldungen, wie du sie oben gepostet hast, oder hat sich da was verändert ?
toschi269
fasse hat geschrieben:Auch hier die Frage, kommen exact dieselben Fehlermeldungen, wie du sie oben gepostet hast, oder hat sich da was verändert ?
Exact die gleichen Fehlermeldungen
Auch hier ist das Problem ist jetzt gefunden. Der Server hat hier keine Lust auf Dateien mit Großbuchstaben.
In der 1.4.1 wird das Problem dann behoben sein.
toschi269
fasse hat geschrieben:Auch hier ist das Problem ist jetzt gefunden. Der Server hat hier keine Lust auf Dateien mit Großbuchstaben.
Supi und danke für die tolle Unterstützung !
