Some problerm with translate file......need help!
yordle
Beitrag von yordle »
I want translate the Admido with chinese-simpfiled,and i try to modify some where in the "en.xml",but it's not work.
please tell me some useful information,how to make the translate file work?
THX!
Thomas-RCV
Re: Some problerm with translate file......need help!
Beitrag von Thomas-RCV »
welcome in the support Forum.
If you change the discription text in the language file, the changes works immediately.
Maybe you Need to delete the browser Cache.
We do not recommend changing the Admidio language packages because they are changed each update.
In case you want to translate use a copy of the XML.
Best,
Thomas
there is also an english Description how to translate into a new language
http://admidio.org/dokuwiki/doku.php?id ... ebersetzen
