Hello,
Is it possible to make a multiple select box or a multiple dropdown?
For example: I have the following:
Trainer
Co-Trainer
Teamleiter
Coach
A user can have several roles, he can be Trainer and Coach.
BerD
multiple select box and multiple dropdown select
Re: multiple select box and multiple dropdown select
one Member can be in different Roles at the same time, so you just have to add the roles you need and add the Member to the roles he has in your organisation.
you can test this in our Demo System... just go to a members account and on the roles you can modify and check more than one "Mannschaft" to include the member to it.
BR
Stefan
BR
Stefan
