Your result of our little server check
here you can post the result of the server check that we announced in the News section.
We use http://www.all-inkl.com and all our tests are ok.
http://www.admidio.org/forum/api
Re: Your result of our little server check
Summary of the posts: (please post your result also if it is already in the list)
Works
  • all-inkl.com
  • easyname.com
  • 1und1.de
  • Strato
  • profihost.com
  • world4you.com
  • justhost.com
  • goneo.de
  • sysprovide.de
  • domaingo.at
  • df.eu
  • aruba.it
Problems
  • Raspberry Pi Debian Jessie
Thomas-RCV
Beitrag von Thomas-RCV »
EDIT 1und1:
Forgot the further test. Sorry
Result:
2a = ok; 2b = Error 404; 2c= Error 404; 2d= Error 404
Thomas-RCV
Strato is working fine
Bullseye
Beitrag von Bullseye »
All-inkl Premium
All tests passed
Jojo
Beitrag von Jojo »
Domain Factory:
Nothing worked for me, gives always 404 error code.
Tested with another subfolder that contains a normal hello-world-index.html file, this worked.
@Jojo:
This is strange. 2a should ALWAYS work. Could you please check if you didn't make any mistake.
Jojo
Beitrag von Jojo »
@Ximex:
What I think maybe could be a problem is the fact that I nedd to upload every website (so also your api folder) into a "webseiten" folder in my root directory, but I can open it without using the "webseiten" path in my url, so I should be able to open http://www.mydomain.de/api. As I said, I tested it with another test folder and a dummy index.html and this worked, so I'm quite sure that I copied it into the right place and called it as you described.
which product do you bought from domain factory?
Jojo
Beitrag von Jojo »
MyHome Plus
# mit dynamischen Inhalten
# 10 GB Webspace
# 10 GB Mailspace
Jojo
Beitrag von Jojo »
Tried it out with a subdomain (subdomain.mydomain.de) in order to get rid off that "webseiten" folder, put the api folder into the subdomains target folder, same problem on performing your tests. The subdomain works, tested this with a dummy index.html on the same level as your api folder.
Hanabi
Beitrag von Hanabi »
Provider: www.1und1.de
Hostingpaket: Unlimited mit CDN (cloudflare)
http://www.hanabi-pirna.de
Result: OK
Zuletzt geändert von Hanabi am 27. Okt 2015, 21:51, insgesamt 2-mal geändert.
Mit sportlichen Grüßen
Thomas
Giovanni9030
Beitrag von Giovanni9030 »
My first webspace is hosted by http://www.profihost.com and all test results are ok.
My second webspace is hosted by http://www.world4you.com and all test results are ok.
Offe
Beitrag von Offe »
Production system:
Strato vServer Debian Wheezy: all test results are ok
Test system:
Raspberry Pi Debian Jessie:
2a = ok; 2b = Fail; 2c= Error 404; 2d= Error 404
Offe: Which webserver do you use on the raspberry?
