Loops back to organization website upon login
huddlejw
Beitrag von huddlejw »
How or what do I need to do to prevent a loop back to the organization website (and out of Admidio) upon login. If one uses the back button on the browser or clicks on a menu item on the right-hand side of Admidio quickly enough, the loop is overridden, but not always.
Re: Loops back to organization website upon login
You can set a relative folder in the preferences > general panel. Maybe this helps.
A complete different link is not possible.
huddlejw
fasse hat geschrieben:You can set a relative folder in the preferences > general panel. Maybe this helps.
This is what I get (on any browser (tried Edge, Firefox and Chrome) and computer) when I login:
1. Login page = okay: http://lapineseniorcenter.org/Admidio/a ... /login.php
2. Logged in = http://lapineseniorcenter.org/Admidio/a ... SUCCESSFUL
3. If I click on the "Next" button or wait: http://lapineseniorcenter.org/Admidio/h ... /index.php
4. If I click on the browser back button or quickly click on the "Overview" link on the Admidio page, I go to http://lapineseniorcenter.org/Admidio/a ... /index.php as a logged in user and everything works from then on.
Putting in different pages/urls (relative folder) under Preferences/General, does not seem to affect this in anyway.
I did a URL redirect under the cPanel that fixes this, but I suspect it's a bandaid approach.
Thanks,
