How to remove list modules
Twito
Beitrag von Twito »
I need to remove it, help
Also, i dont like admidio to be in a sub folder on my webserver. I prefer it eg: http://www.example.com
Re: How to remove list modules
Hi Twito,
since now it's not possible to disable the List module but you can hide all lists for common users, so they won't see any list.
Best regards
You could put the admidio code also in the root folder.
