installation issue
dc_rogers
installation issue
Beitrag von dc_rogers »
I am having trouble getting past the "install database" portion of the install. I have attempted at least 3 separate times. the ONLY difference I am making is the database login because I do not want to give it root access direct (I modify the privileges within the MySQL) and the prefix because if I do like it I intend on running multiple installations and donating to help support admidio.
I receive no error messages except for the spinning symbol after I click "begin installation." What have I missed?
respectfully,
DC Rogers
edit: I did let it attempt to "install" the database overnight with no change in status.
jbrown
Re: installation issue
Beitrag von jbrown »
This happened to me, too.
I almost abandoned the software because of it.
Hit the "refresh button on your browser, it worked for me.
Could you please test it with a different browser. Did that work?
We found and fix the installation issue. It only occurs if you use PHP8.
Please download Admidio 4.0.6 and try the installation once again.
mrlawrencelam
Beitrag von mrlawrencelam »
Version 4.0.6:
When I first installing with MS-Edge, I chose a less secure Administrator password and was rejected by the installation process. After that, although I have used a very strong password, the installation process kept halting at "CREATING DATABASE". No matter how many times I tried with a clean setup, it always stopped at this stage.
I then changed to Firefox and the installation went well until the end.
accordeonadmin
Beitrag von accordeonadmin »
I have an installation issue too, however, it is one where the DB is OK, but the program will not let me in.
I installed the latest version (4.0.6?) from the admidio site (not softaculos), I had a backed up DB, but from the start, I am asked to update the DB to 4.7.
Fair enough, but then I get a login screen, but I just cannot get past that, my DB is intact, but my credentials don't seem to work anymore and there is no "Forgotten password" link, although I am sure my credentials are right.
Any file I can recover my credentials from, or any way I can manage to log in so I can get admidio to work again?
Thank you in advance.
