CAPTHCA not working
Fidelanten
CAPTHCA not working
Beitrag von Fidelanten »
When going to the /adm_program/system/password_reset.php page,I get a captha box but that is more or less empty, Only some lines are seen. As I am preregistering all the members, I whould ike to skip tha captha box all togehter. Is that possible? My whish is that the pregeistered users get credentials (passwords) just by entering their email address, with no captcha.
Thanks for any thoughts,
Staffan
Re: CAPTHCA not working
You can aktivate / deaktivate the captcha in every module settings. Go to settings > registration or settings > messages and deaktivate the captcha.
Fidelanten
Thank you fasse,
I gave it a try but then... I changed my mind. I will go with CAPTCHA after all.
But still - all my members are preregistered, and self registration is disabled, so the only case when CAPTCHA is needed is at the Forgot password page.
So, I am back where I started. CAPTCHA doesn't show any letters. See img. I have tried different typefaces and settings but to no avail. I have no idea where to look. Any suggestions?
http://www.fondoptioner.net/docs/220930 ... aerror.jpg
Can you please check if the PHP gb-support is enabled. You can go the Admidio preferences in the php section and click the link to phpinfo(), after that please check if settings in the GD-Support section. This should be enabled .
Fidelanten
Thanks again,
Seems enabled. Below is everything under that section. Further below are some general info, if my setup is causing the problem. Everything else works perfectly. Just the letters in the CAPTCHA don't work.
GD Support enabled
GD Version bundled (2.1.0 compatible)
FreeType Support enabled
FreeType Linkage with freetype
FreeType Version 2.9.1
GIF Read Support enabled
GIF Create Support enabled
JPEG Support enabled
libJPEG Version 9 compatible
PNG Support enabled
libPNG Version 1.6.34
WBMP Support enabled
XPM Support enabled
libXpm Version 30512
XBM Support enabled
WebP Support enabled
Directive Local Value Master Value
gd.jpeg_ignore_warning 1 1
PHP Version 7.2.26
Windows Server 2012 R2 Datacenter Edition
MySQL Community Server 5.5.45
