Change history for themes in version 4.3
This page lists all changes in the theme folder for the Simple theme within version 4.3. If you are still using version 4.2, check the page there to see if you have made all changes within 4.2. If you are still using version 3, first update to version 4. This will also replace the complete theme folder. If you already use version 4.x and want to update to a newer version 4.y, this page can help you.
The changes shown here always refer to our default theme Simple. If you have made changes here, you may have to take them into account in the customizations. If you haven't made any changes to the theme yet, or if you can restore them yourself relatively easily, you can simply replace the theme folder.
If your changes are bigger and you don't want to simply replace the theme folder, all changes are documented here and you have to add them to your theme yourself. Check which version of Admidio you have used so far and look for an entry that corresponds to this version or higher. You have to update all documented changes from this entry on.
Version 4.3.14
Version 4.3.10
- Add within the file
adm_themes/your-selected-theme/css/admidio.cssthe following code (around line 537):.card-img, .card-img-top { height: 200px !important; object-fit: cover !important; } .admidio-album-thumbnail .rounded { width: 100% !important; object-fit: cover !important; }
Version 4.3.8
adm_themes/your-selected-theme/css/admidio.cssthe following code (around line 418):.admidio-blog img, .admidio-card img { max-width: 100%; height: auto; }
Version 4.3.7
- Search within the file
adm_themes/your-selected-theme/css/admidio.cssthe following code (around line 518)::.admidio-event-highlight .card-header, tr.admidio-event-highlight { background-color: #cccccc; }
Replace the block with this code:
.admidio-event-highlight .card-header, tr.admidio-event-highlight { background-color: #cccccc !important; }
Version 4.3.0
When updating from version 4.2.13 or newer, the following files in the theme folder must be adjusted.
(if you have not made changes everywhere, you can also simply replace entire folders and, for example, only adjust the CSS folder manually)
- Add the folder
adm_themes/your-selected-theme/templates/modulesto your theme. You can take this from the Simple theme from our package.
- The following files must be added to the corresponding theme folder. You can take this from the Simple theme from our package.
adm_themes/your-selected-theme/templates/sys-template-parts/form.select.tpladm_themes/your-selected-theme/templates/sys-template-parts/form.static.tpladm_themes/your-selected-theme/templates/sys-template-parts/menu.functions.tpladm_themes/your-selected-theme/templates/sys-template-parts/menu.main.tpl
- The following file must be replaced in the corresponding theme folder:
adm_themes/your-selected-theme/templates/message.tpladm_themes/your-selected-theme/templates/message_modal.tpl
- Search in the file
adm_themes/your-selected-theme/templates/index.tplfor the following code (approx. line 40):// function to handle modal window and load data from url $('.openPopup').on('click',function(){
Replace this block with the following code:
// function to handle modal window and load data from url $(document).on('click', '.openPopup', function (){
adm_themes/your-selected-theme/templates/index.tplfor the following code (approx. line 112):<div class="admidio-headline-mobile-menu d-md-none p-2"> <span class="text-uppercase">{$l10n->get('SYS_MENU')}</span> <button class="btn btn-link d-md-none collapsed float-right" type="button" data-toggle="collapse" data-target="#admidio-main-menu" aria-controls="admidio-main-menu" aria-expanded="false"> <i class="fas fa-bars fa-fw"></i> </button> </div> {$menuSidebar->getHtml()}
{include file='sys-template-parts/menu.main.tpl'}
adm_themes/your-selected-theme/templates/index.tplfor the following code (approx. line 83):<a class="nav-link" href="{$urlAdmidio}/adm_program/modules/profile/profile.php">{$l10n->get('PRO_MY_PROFILE')}</a>
<a class="nav-link" href="{$urlAdmidio}/adm_program/modules/profile/profile.php">{$l10n->get('SYS_MY_PROFILE')}</a>
adm_themes/your-selected-theme/templates/index.tplfor the following code (approx. line 153):{$menuFunctions->getHtml()}Replace this block with the following code:
{include file='sys-template-parts/menu.functions.tpl'}
adm_themes/your-selected-theme/templates/overview.tplfor the following code (approx. line 38):<div class="admidio-overview-plugin col-sm-6 col-lg-4 col-xl-3" id="admidio-plugin-sidebar-announcements"> <div class="card admidio-card"> <div class="card-body"> {load_admidio_plugin plugin="sidebar_announcements" file="sidebar_announcements.php"} </div> </div> </div>
<div class="admidio-overview-plugin col-sm-6 col-lg-4 col-xl-3" id="admidio-plugin-announcement-list"> <div class="card admidio-card"> <div class="card-body"> {load_admidio_plugin plugin="announcement-list" file="announcement-list.php"} </div> </div> </div>
adm_themes/your-selected-theme/templates/overview.tplfor the following code (approx. line 45):<div class="admidio-overview-plugin col-sm-6 col-lg-4 col-xl-3" id="admidio-plugin-sidebar-dates"> <div class="card admidio-card"> <div class="card-body"> {load_admidio_plugin plugin="sidebar_dates" file="sidebar_dates.php"} </div> </div> </div>
<div class="admidio-overview-plugin col-sm-6 col-lg-4 col-xl-3" id="admidio-plugin-event-list"> <div class="card admidio-card"> <div class="card-body"> {load_admidio_plugin plugin="event-list" file="event-list.php"} </div> </div> </div>
adm_themes/your-selected-theme/templates/overview.tplfor the following code (approx. line 52):<div class="admidio-overview-plugin col-sm-6 col-lg-4 col-xl-3" id="admidio-plugin-sidebar-online"> <div class="card admidio-card"> <div class="card-body"> {load_admidio_plugin plugin="sidebar_online" file="sidebar_online.php"} </div> </div> </div>
<div class="admidio-overview-plugin col-sm-6 col-lg-4 col-xl-3" id="admidio-plugin-who-is-online"> <div class="card admidio-card"> <div class="card-body"> {load_admidio_plugin plugin="who-is-online" file="who-is-online.php"} </div> </div> </div>
